Phil200tdi
- Sep 8, 2009
I have recently purchased an ST3 remapping unit from GCLtuning which connects to the OBDii port.
The unit connected to the vehicle and read the original map from the ECU fine, but when I tried to upload the upgraded maps returned from GCL the unit suddenly lost power. GCL originally thought this could be a resistor in the cable and sent a new cable, but this has not rectified the problem. Now they are adamant that it is the K-line to the OBD port, is this likely to just be a fuse (and if so which one) or something more serious? Or is the problem more likely to be with the unit itself?
Anyone come across this problem before?
Cheers
Phil
Cheers
Phil
