AzmiQ
- Mar 6, 2024
- Mercedes 2003 C200K (W203)
Hi all,
I have a C200K (W203) 2003 model which recently started to act up.
The problem started with the automatic windscreen wipers not working. I have to keep holding the stick to get them to work. Sometimes, when I signal left, the automatic wipers work.
Then the instrument dashboard light started dimming after time. When I first start the car, it's ok and bright. But then it starts to dim the more I drive until it is no longer readable.
Then the driver-side automatic window started to "lose power" as well. When I first start the car, everything is fine. But after I drive a bit, it stops rolling back up.
Today, I started the car and the whole dashboard wasn't working. No warning signs. No lights. Even the speedometer and the petrol meter didn't move.
After removing & inserting the key multiple times, they worked again, but now the SRS restraint system control worning is on.
I checked all the fuses and couldn't find any fault in any of them. I had the window switch checked, and there doesn't seem to be a problem in it.
I'm not sure where the problem is, whether it's a faulty SAM or a battery issue or what exactly.
I took it to a garage and they couldn't figure out what's wrong with it. I'm due to take it to another garage soon, but I'd like to have a general idea what to look for so that we don't miss anything this time.
Apologies for the long post.
Thanks!
Thanks!
