Odometer replaced by dashes
kennyscott6
A160/2010/1498
W169 odometer displays mileage for 2 seconds then disappears and shows 4 dashes/lines? Has anyone else had this problem?
K
kennyscott6
A160/2010/1498
Has this just started happening?
No it's been like it for 6 months. Mileage reads perfectly clear for a few seconds, say 71274 then disappears and 4 small lines appear ----
mersum1es
Finland
What parts has been changed? ---- means usually wrong mileage in some of the many parts which store the mileage. Usually happens after cluster change, sometimes when service records has been 'corrected' otherwise.
Communication error with the EIS is most likely. Possible somebody has been in there with mileage alternation tools at some point. Some diag should give you a clearer idea.
mersum1es
Finland
w169 mileage can be found DASH (KI or IC), EZS (EIS), ASS, AS+ and ESP.
K
kennyscott6
A160/2010/1498
I will have to take it to someone local in Romford who has the correct software. Thanks for your advice
Alex above is fully equipped and a well respected indy not far from you. If it can wait till after he reopens after lockdown he would be a good place to go.
Rappey69
hants
c220 w204 amg sport
I changed my dash on my previous mercedes due to failure and then had this problem.. Took it to mbs who got the satnav dash board display working again but could not get the mileage to display.
K
kennyscott6
A160/2010/1498
Just want mileage to display for the MOT. I don't want the tester to write NO ODOMETER on the certificate
Tel: 020 8863 9233
