brandwooddixon
- Jul 31, 2006
- Location
- Wolverhampton
- S63 Coupe 2014
They commonly corrode near fixing points and leak.
Don't run the engine until the pipe has been replaced and you may get away without replacing the pump.
From what I remember the rear pipes are difficult to fit as they pass over the rear subframe.
The circuit runs at 3000psi and in theory a good specialist could fabricate the pipe or you could buy a new pipe and have it split (away from a mounting point) and a new connection added to make fitting easier.
Sorry I can't remember the price of the fix nor the il capacity of the system, but you need to factor in new oil at £20 per litre.
