outsmartsmart
- Mar 23, 2008
- Location
- Warwickshire
- 1995 A124 E320 Sportline
Well bolts actually.
Just bought some Merc' 18" wheels to replace the standard 16" on my E class and was fiddling around trying to hold the wheel and get the bolts in, I always find this a b*tch to do.
After lying flat on my back and KNOWING the bolt holes in the wheel were DEFINATELY aligned to the threaded hole in the hub and still not understanding why they wouldn't screw in I used my head and took wheel off and pushed bolt through the wheel to see...................about 2mm of thread showing. So THAT'S why they wouldn't bolt up:Oops:
On standrd rim about 12mm of thread showing. The threaded shaft of the bolt up to the tapered 'collar' (including the unthreaded element of it) is about 26mm so I guess I need 36mm long instead.
Is this a standard bolt and what is best source for them (seen wheel bolts on eBay) and I guess I need new locking bolts also..........starting to get expensive now
