Oil Filter Location?
Fazeel
Hertfordshire, UK
Hi can someone please tell me where abouts the oil filter is in my car as I need to change it...
Many thanks.
Its under the rear offside just in front of rear wheel, you will have two pumps and the in line filter is part of this assembly, make sure that you fit it with the arrow going in direction of fuel flow. you will have to clamp the pipes or have a very low tank and jack the car.
Malcolm
Chazchuzzlewitt
Dorchester
W/S124 320TE Estate
um, I think he meant the oil filter Malcolm :)
1984 280E would be a 123 with 110 engine I think- the oil filter is hiding on this engine- under the right-hand side (looking from the front), silver canister which has a bolt running through the middle then comes off with a paper element.
F
Fazeel
Hertfordshire, UK
Hi sorry Malcolm I should have been more specific I needed to know where the engine oil filter is I've changed the fuel filter that wasn't a problem finding, if you can please guide me to where the engine oil filter is please?
Fazeel
So sorry about that Chaz, it must have been the excitement of going to see my next car.
malcolm
