Oil filter wanted
Mark Atkins
I need a replacement oil filter (cartridge replacement) for my '94 E220.
Does anyone know of a site where I can order on - line? I've had a trawl through a number of search engines but nothings turned up..
Thanks for any help.
Mark
C220GJS
Shotts, Scotland.
1995 W202 C220 Elegance
Go to any motor factors or Halfords or even an MB dealer ;if you want the original part; and you will get one over the counter. Why would you order one on line?
If you must, try ; Eurocarparts.co.uk
tom7035
Mark, a wee bit of advice, for a few extra pence get a new sump plug also. If it's not already well 'chewed up' it's likely it will be before you get it out (no disrespect, they're usually pretty tight and the bolt-head is soft). It's a 13 mm by the way.
M
Mark Atkins
Thanks for the advice.
You're probably right, better to buy over the counter - expect the postage will be more than the filter itself!
Also - had forgotten about the horrors of the stripped sump plug (a bad indication that I'm not changing the oil enough :)
Rgds
Mark
Parrot of Doom
Manchester
The oil filters from a dealer are surprisingly cheap, you're only taking a couple of quid difference. As others have said, get a new sump plug and washer.
C220GJS
Shotts, Scotland.
Re. the sump plug ,if you use a good quality single hex. socket you should not have a problem.
