Oil going thru my turbo from the engine help please
Martlisa
2012 Mercedes c220cdi Amg plus
Hi
I’m new to the site and have owned a lot of Mercedes I no most common faults but
I was hoping someone could help me with a problem I have il try to keep short lol
My car broke down on the motorway
2012 Mercedes c220cdi 125kw amg plus 7g auto 80k owned for 3yrs
My wife said it made a weird noise and it felt like it started a dragging feeling as she kicked down then it started smoking she managed to get to hard shoulder turn it off then she tried to start again and it started but was running really rough
Then cut out wouldn’t start that’s when we got it recovered
The garage said more than likely turbo
so had that replaced yesterday 11/06/21 with a good used low mileage turbo with warranty
they called today and said the new turbo was doing the same throwing the oil straight thru it into the Dpf again
Any help would be greatly appreciated
Thanks for looking
did your mechanic even suggest the pcv / crank case valve.
If not he is crap.
I mean, a stream of oil out of the turbo into the dpf is excessive even for a crankcase valve. PCV also goes into the intake so engine would likely runaway if it was pcv related. if not turbo, then internal engine issue.
Gazwould
C250 CDI
Biturbo on these .
Martlisa
Martlisa
Hi thanks for reply’s guys no the mechanic never mentioned those parts
And yes it it bi turbo looks like a new engine needed strange as it only done 80k
Martlisa
Martlisa
Do you think I should try the valve replacement or any other ideas before I need to find 2k + for an engine lol
Probably not a bad idea to get a second opinion! :)
Martlisa
Martlisa
Hi
I have looked and looked for the pcv valve / oil separator valve for sale for the w204 can’t find one every other model except mine lol
Do you know where to find it ?
Also do you no the location of the part ?
I think it’s on top of the valve cover on top of the engine not sure tho
Location - google
Source - MB.
It may not be the definitive cause of your issue but a relative cheap check.
Did you get a second opinion.
oigle
members.optusnet.com.au
2nd opinion should be mandatory - not just a thought.... You shouldn't spend serious money without double checking. PCV is a red herring. Your mechanic has already made one error at your cost. Easy to throw money at it.
Ian.
www.ckinsurance.co.uk
