chalcedony-blue
- Apr 6, 2009
- Thread Starter
- Thread starter
- #21
thanks again
This has gone off topic a bit... my fault.
Thanks to all... and to Busby20 for the part numbers. I have now located the check valve. It falls under the compressor section for the engine. For my car (M111.975 engine) the part number is: A002 140 68 60
Item 38 in the image below.
I have seen reference somewhere that the valve is located at the very back of the engine. In this case (W208 CLK230K) it is mounted to the exhaust manifold side of the engine.
The valve can be be seen by peering down between the exhaust manifold. There is a stainless steel bracket/pipe fitted at this point to which the valve is fitted.
Update.
I eventually changed the secondary air injection valve. Once I removed it I discovered that the old one was just masquerading (externally) as a one way valve but (internally) it had failed.
There was quite a bit of crud inside which was compromising the sealing faces. It's a sealed unit so a replacement was required.
The difference in overall performance was quite impressive. The engine now pulls like a train throughout the rev range.
In this instance it appears that the secondary air injection valve was the culprit and was causing MAF like failure symptoms when driving.
For my car (M111.975 230k engine) the part number is: A002 140 68 60
You will need a 27mm open ended spanner to get the thing off. I had to grind down the spanner to make the jaws thinner as the standard 27mm is too thick to fit the flats on the underside of the valve.
It's a DIY job, but you will need to pull the air box and associated pipework off to get decent access to the valve.
Hi, I've had this problem in both my SLK 230's kompressors (same engine etc. as your CLK) which required a full harness replacement on both at considerable costs whilst the older of my SLK's has had no problems with oil contamination in the MAF the later one has had constant problems with contamination and the problems that go with it - very annoying!Just to let you know, car is almost back together, new sparkplug shaft seals fitted today, thanks to dad making an ingenious tool to do the job
Got mod wire from mb, plan on putting that on tomo aswell as looking at this secondary air intake valve, so keep you posted on that.
Got qoute from indie in luton £370+ vat + 4 hrs labour to do new harness although my husband (electrician of sorts) is making noises about just replacing the wire that comes from camshaft connector and replacing it all the way back to the ecu as he cant see how the whole harness could be affected, only this part!! Now as you know we are no mercedes mechanics so has he lost his marbles or is this possible? Has this ever been attempted do we know or are we completley missing something???
Keep you posted
Julie
I have read various posts on Benzworld which address this problem, mostly it points to the "Oil Separator" which is located on the rocker cover between the rocker cover and the kompressor air box. If this is faulty it allows oil to be drawn from the head, through the airbox, down the intake pipes, through the MAF (consequently contaminating it,) and into the manifold.
If you want to find out more just google "Oil Separator SLK" and you will get various links.
Sorry busby, but I am inclined to disagree with the suggested Benzworld root cause of oil finding it's way to the MAF from the rocker cover.
Please see my DIY post on the subject which also highlights the valuable research carried out by jimsinessex who put a lot of time into this when he owned his W208 CLK230K Coupe. Sadly that car was trashed through no fault of Jim.
I believe the generally accepted cause (on this forum anyway) of oil being forced from the oil separator on the rocker cover is as a result of a failure/blockage of the lower part breather system located under the inlet manifold. As a rule it's the two brass nozzles (fitted to the cylinder head) which block and cause back pressure in the breather system. When this happens an over pressurisation of the upper breather system takes place which then results in oil being forced down the route you describe.
Please see this link for a detailed coverage on the subject.
The fix is cheap for parts but takes a bit of time on the labour front. If the person needing to do the job is a competent DIY mech then it's do-able.
In summary, if the engine (CLK230K W208 or C class W202) has engine oil working it's way down to the MAF from the rocker cover via the airbox then this is the most likely cause.
As an aside.
Sometimes when oil has been seen on the MAF the phrase 'supercharger failure' has been known to be uttered.
Oil seen on the MAF is nothing to do with oil coming from the supercharger oil reservoir itself. The simple reason being that the supercharger does not have a pressurised engine oil feed for the bearings, unlike turbochargers. Plus, if a supercharger bearing seal was to fail the positive pressure of air inside the unit would force what little oil it has (in it's own isolated reservoir) out of the failed seal into the big wide world and not down the pressurised air feed tubing via the intercooler to the MAF.
