Oil Leak
Discussion in 'Engine, Drivetrain, Fuel and Exhaust' started by jberks, Nov 17, 2012.
  1. jberks
    jberks Senior Member
    11,117
    May 12, 2004
    Your Mercedes:
    Should be an easy one for you guys (I hope).
    Opened the bonnet to be greeted by this.
    Is it just a split breather hose or is this commonly caused by a blockage etc?
    (2005 E270CDI 142k)
    cheers
    JB
  2. OP
    jberks
    11,117
    May 12, 2004
    Your Mercedes:
    nobody any idea?
  3. scotty2hotty81
    scotty2hotty81 Senior Member
    132
    Nov 1, 2006
    Not many cdi's that don't leak from there, I wouldn't worry to much, if it bothers you change the pipe and sensor,5 min job.
  4. OP
    jberks
    11,117
    May 12, 2004
    Your Mercedes:
    Thanks. I guess mine used to be one of the few. Do I have to change both the pipe and sensor (which leaks?) or do they come as a single unit.?
Share This Page
