martinaltury
Hi all ( pist off from valencia ) i changed the rocker cover gasket i thought
the oil was from them as its at the back of the engine right were the starter is
but no on closer look it may bee sump gasket as there is oil in the bottom
of the bell housing in the small hole in front of the exhaust cross over.
the rear crank oil seal is dry so its not that can you get the sump off with the engine in the car . any body have any thoughts if it can bee from any were
else its the v6 3.2 and its in my clk
thanks martin
thanks martin
