Oil leak
scorpio stu
Essex
E230 Estate 1997 P reg in Silver & Navy Chrylser PT Cruiser with all the chrome
Car has been into the mechanics today for a new shock and to check an oil leak.
He has said it is the head gasket oil leak.I'm no mechanic so does that sound like a common fault. He alos said it is not worth doing as its such an expensive and time consuming job. £5-600 ?
Just keep an eye on the level but it will lose minimal oil. The most annoying thing is the small oil spots on the drive.
The car is a 1997 P reg E230 estate Auto. Just bought it so not sure what w it is as I am not up to speed on all the Merc talk yet !
Cheers
Stu
If the leak is at the front it is a timing cover off and not the head gasket,,where is it leaking from
scorpio stu
Essex
Its difficult to see but it looks wet around the front but I can't see the rear of the engine
As earlier if it is leaking from the front timing cover, this can be removed on its own, and re sealed, OK the crankshaft damper has to come off, but not a head off job
scorpio stu
Essex
Just had a good look and can only see oil from the front . TV is this a big job and is it somethingvice could attempt ?
The fan and tensioner have to be removed, along with some other parts,, I will dig out a worksheet for it
scorpio stu
Essex
TV just came across this post,did you ever find the work sheet ?
5pares
Suffolk
E320cdi
Could it be the front bolts that come loose and require retorqueing?
I have sent you 5 or 6 service sheets I have no idea what is on them let me know please if you need more
www.W140.co.uk&www.r129.co
