Mike Buley
Can someone please answer a query I have regarding oil pressure, and if mine is ok?
Starting up is a bit lumpy, but given a bit of welly the gauge goes up to 3.
Gradually if I leave it idle it drops.
When the engine is fully hot, the engine idles at just over 1.
When applying acceleration, goes to 3.
When lifting off the accelerator, but still going ahead, but losing revs it drops to 2 ish, but when I apply pressure to the pedal it goes up to 3.
Is this normal??
Also, the oil light came on yesterday, couldnt check the level correctly as I was making pretty good progress down the motorway, but there was oil in it, so I popped about half a litre in, and off I went, no problems.(no light)
Thanks folks,
Mike.
Is this normal??
Thanks folks,
Mike.
