bigasotonuk
- Nov 14, 2006
- Age
- 56
- Location
- Southampton UK
- C43/55 AMG 1999 / C230K 1997
As some of you are aware I have for some time going to be fitting OEM Xenons together with Headlight Wash/Wipe, to maintain a legal Xenon fit, electric auto-levelling needs to be fitted, this requires fitting of a ECU, Wiring loom, and front/rear suspension atitude sensors. Fitting of the loom involves me having to remove all the coverings and linings in the front footwells of the car. After removing of the passenger side linings, I noticed there was oil at the foot of the bolted steel plate at the foot of the footwell, which houses the new levelling ECU.
I intially thought this was the oil that is suspended in the refrigerant gas of the A/C as I have been having some issues with it.
I made a phone call and had a chat with a fellow forum member, and think we have identified the problem, and hopefully a cheap solution.
But I thought I would post this and see if the forum think the same as me (and the fellow forum member).
There is a pic, quite poor I,m afraid, the oil had slightly pooled but I had wiped it up before I took the pic, so only the oil on the looms is left (beside the oil soaked up in the soundproofing). The oil is dirty black and about as thin as 3 in 1 oil, with no discernable smell.
Heres the pic, so what do we think it is?
