Ola! A South African in Portugal
Jiggz
New Registration
W202 250D
Hi all
I have had three old Mercedes-Benz in the past - a W116 350SE, a 280SE (can't remember what W number it had - it was an 1982 IIRC), and a W123 240D (wish I still had that car).
A friend here on the farm in Portugal has a W202 250D and he has the starting problem caused by air ingressing the injection system. He has apparently had the clear pipes and O-rings changed, as well as some seal between the shut-off valve and the block, but still nothing has cured the problem. There is a language barrier, and I don't want to throw shade but I am not sure about the mechanic he has been using.
My friend is an accountant and NOT mechanically minded.
So, I will be trawling through the forums here to see if I can find the fix...maybe the O-rings on the shut-off valve ends and maybe something on the....is that a pre-heater below and connected by a short pipe to the shutoff valve??
Maybe something on the injector pump??
I may as well do the whole lot.
Anyway, I will take a look around for what I need....thanks in advance for the info I will find.
Cheers!
Hello and welcome
A.J.
Norwich. UK
Hi and welcome to the forum :)
00slk
Cambridgeshire UK
Hello and welcome
Srdl
Hampshire
GLC43 AMG 2018 (X253)
SmartAmg
2011 E class coupe 350 CDI
hopeful
clk cdi2.7 auto coupe 2005
hopeful
Hi all
Cheers!
my old 250 had bad leak off pipes and air in the clear pipe to pump, put a one way valve in ,helped starting
