Old banger seeks others similar...
Discussion in 'Introduce yourself' started by Tom Bettle, Jun 8, 2019.
  1. Tom Bettle
    Tom Bettle New Member
    Jun 8, 2019
    Your Mercedes:
    ML270/04/2.7cdi
    Hello,
    I’m a newbie and frankly not a car geek, but I’ve had three ML270’s over the years so I must have a soft spot for them.
    I’d love to know how to fix the irritating rattle that stems from somewhere in the boot (all three have had the same rattle!).
    Mine is an old 04, still drives well except I think it’s getting Black Death as it’s getting carbon deposits under the plastic engine cover.
    It also shakes like hell at 52mph, sometimes at around 60 and also at just over 80 not that I ever go THAT fast. .
    Lastly it has knackered headlamp height adjusters which I’d love to know how to fix.
    Other than that, I love the car. It’s s banger with rust in the usual places, but it’s a work horse. Drives nice on the motorway assuming you avoid the speeds it shakes at.
    Oh... the fumes coming into the cab are “interesting” so I tend to put the air con on recycle... guess that’s to do with the Black Death?...
    Hello all!
  2. Blobcat
    Blobcat Moderator
    15,517
    3,865
    Near Grange Moor (not Wakefield...)
    Your Mercedes:
    R171 SLK280 3.0, Land Rover 110 County SW
    Hello and welcome
    Tom Bettle likes this.
  3. LostKiwi
    LostKiwi Senior Member
    19,040
    8,877
    Aug 25, 2006
    Your Mercedes:
    '93 500SL-32, '01 W210 Estate E240, 02 R230 SL500 (Malcolm Spec), 04 Smart Roadster Coupe
  4. McDonald
    McDonald Senior Member
    985
    797
    Apr 11, 2017
    Surrey
    Your Mercedes:
    SL500 2004
    Welcome Tom, it doesn't sound ideal. I hope one of the more practical folk are able to advise. I'd be inclined to take it to a good MB indy and get some professional help with it. Best of luck anyway.
  5. OP
    Tom Bettle
    Jun 8, 2019
    Your Mercedes:
    ML270/04/2.7cdi
    Hi and thanks,
    I did try that, but the overall cost to get everything sorted was about twice the value of the car...
    I’m kind of just enjoying it until it falls apart!
  6. Srdl
    Srdl Senior Member
    2,321
    1,154
    Oct 8, 2015
    Hampshire
    Your Mercedes:
    GLC43 AMG 2018 (X253) Premium Plus
    Hi Tom and welcome to the forum. I’m not a techie but I’m sure someone on here will want to help you rescue a much loved old banger! ;)
    If you get nowhere in this “Introduction” section, it might be worth posting threads under some of the technical sections.
    Edit... have just seen your other post in one of the technical sections - you beat me to it!
  7. sonic
    sonic Senior Member
    1,012
    357
    Nov 21, 2009
    Staffordshire
    Your Mercedes:
    E350CDI, SLK200K, FJR 1300
    Welcome had a CLK270CDI did 120K miles in it, a great car.
  8. John Laidlaw
    John Laidlaw Senior Member
    20,756
    5,766
    Nov 15, 2013
    Wirral
    Your Mercedes:
    UnMercs BMW i8 Volvo XC90
  9. PB53CLS
    PB53CLS Senior Member
    67
    14
    Jun 24, 2016
    Paisley
    Your Mercedes:
    2010 CLS350 CDI Grand Edition
    Hi Tom,Never had an ML,but not so long ago i had to replace my headlight adjusters on my 2010 CLS.There is one behind the F/O/S wheel,and one one on the R/O/S axle,about £30 each from MB Grangemouth.Hope this helps....PB
  10. Taffy7hfa
    Taffy7hfa Senior Member
    885
    229
    May 29, 2016
    Oxford
    Your Mercedes:
    ML 270CDI 2002 Fully loaded. 2014 Peugeot 308 1.6 HDI. 2012 Suzuki Alto.
    Welcome to the forum Tom, I wouldn't ignore the leaky injector seal(s?) too long, could get expensive.
  11. Blobcat
    Blobcat Moderator
    15,517
    3,865
    Your Mercedes:
    Contractor that used to do some work for me had his ML270 go up in flames on the M4 because his injector popped out.... sprayed fuel over the hot exhaust and that was the end of his ML (Mercedes had helicoiled in the injector...)
  12. kid-jensen
    kid-jensen Senior Member
    893
    149
    Nov 13, 2002
    Epsom Downs, Surrey
    Your Mercedes:
    Ml320CDI 2007
    The shaking is almost certainly tyre balance.,
    You can confirm by borrowing a known-good set of wheels, or swapping them front-to-back..
  13. OP
    Tom Bettle
    Jun 8, 2019
    Your Mercedes:
    ML270/04/2.7cdi
    Had them rebalanced the other day... made no difference...
  14. kid-jensen
    893
    149
    Nov 13, 2002
    Epsom Downs, Surrey
    Your Mercedes:
    Ml320CDI 2007
    You could have a dented or distorted rim that would still make the car shake, even though it has been balanced.
    Generally, it's the unseen, inner rim that gets bent (because it it's unsupported). Get all 4 wheels off the ground and run the car in drive (slowly!) and check for eccentricity or rim damage
  15. Frontstep
    Frontstep Senior Member
    6,804
    740
    Apr 22, 2007
    Your Mercedes:
    T210 320cdi
    I can't think a competent wheel balancer wouldn't spot a rim like that.
  16. kid-jensen
    893
    149
    Nov 13, 2002
    Epsom Downs, Surrey
    Your Mercedes:
    Ml320CDI 2007
    Well, they didn't spot mine!
    I guess I can safely call them incompetent then...
Share This Page
