tpn
- Apr 13, 2022
- S204 OM651 2012, Daimler V8 250 X 3
I have a 2012 204 Estate. Some time ago I hit a bad patch on a country road and the eml came on and car went into limp mode. Long story short the second bolt on the bottom of the inlet manifold snapped-I found it in the tray.
I knocked off the light with an Icarsoft MB11 and once I did not accelerate quickly the light and limp mode stayed off.
On a trip from Liverpool to the Cotswolds I noticed that the Icarsoft showed a P245328 fault "Soot content not OK mechanical fault."
It was showing a 400% fill and 3g soot. I did a driving regen and it brought the fill down to 0 and created 3g ash.
It then started passive regen very often but the fill content never reduced below 10%.
I recently put in a new inlet manifold, cleaned the EGR, put in a new thermostat, and diesel filter housing. No fault codes and no limp mode. Driving perfect.
Took it on short trips for a day or two without a problem, then yesterday after a 40 mile trip I noticed on the Icarsoft the following two faults. (no limp mode and no light on)
P246309 Soot content not OK, mechanical fault. Content was 283%. Soot 6g. P245328 "input for differential pressure sensor 1 in the DPF has a malfunction, invalid signal"
I was parked at this stage so decided to leave it until this morning.
This morning the Fill level had gone back down to 92% even before it was started. Took it for a drive, it did a passive regen at 100% but brought the fill down to 10% only and 2g of soot.
It then increased quickly to 60%, then suddenly dropped down to 40%, then did a passive regen again, this time to 20% fill.
No codes, no limp mode, back pressure etc within allowances. Only thing I noticed that may not be correct is that the B28/5 Pressure Sensor downstream of air filter stays constant at 1.00 bar. Any experienced ideas. oh, and the injectors appear to be ok also.
I am thinking of changing the Differential Pressure switch
