Om624 glow plug removal
matthew k
Winchester Hampshire
2005 320 cdi Sport 7 seat estate
Hi, my cars needed new plugs for a while, so I'm soon to bite the bullet. I've ordered some made by Bosch, they looked closest to the Mercedes originals to me. Just a thought, does the diesel itself come into contact with the plug before it's injected? Must admit I have no idea how it works on a direct injection engine.
I just thought maybe some fuel cleaner added a few days beforehand might help shift any carbon that might cause them to be stuck? Cheers
EmilysDad
Bury Lancs
ML350
Fuel cleaner won't make a difference. You could give each of the plugs a squirt with a proper penetrating oil eg Plusgas a few times. Make sure the engine is fully hot before you start .. be careful & don't force the if they don't want to come out, they easily shear.
KennyN
Paisley
BMW 440i, Cayenne, ZX12r / ZRX11 / ZRX Monoshock
I think you mean the OM642 engine ?
The plugs can be a bit of a PITA to replace , you maybe lucky and they come out without a fight but it is not unknown for them to shear in the process.
To give yourself a chance before attempting removal give all six a good dose of penetrating fluid for a few days before / after using the car that way it gets a chance to work into the threads.
Penetrating fluid / ceramic grease for re-assembly / torque wrench / 8mm deep socket.
K
Frontstep
T210 320cdi
Keep a well fitting socket square on , don't snatch and tighten ever so slightly first.
As said a hot engine and some penetrating oil, not WD40 it doesn't do much which is why WD make a specific one.
I have heard good reports about using an impact gun.
I think something to remove carbon in the cylinder isn't a bad idea if it works.
There's plenty of google images showing where your fuel,plug and injector sit in the cylinder head.
Uncle Benz
West Sussex
Mainly Mercedes
Engine hot hot hot. I use a 1/4” drive socket set, gives a better feel for the yield point than a 3/8 set. Often a very slight nip in the tighten direction first, then loosen sees them come straight out. I’ve never broken one. If it isn’t shifting, plusgas and run for a week, then try again
Frontstep
T210 320cdi
They are a pathetic design fraught with disaster.
As our humble cars evolve feeble electronics held on with gnat wing spit will blight our lives next.
