OM642 cold starting
HERBIEMERCMAN
PRESTON, LANCS.
97. E300.TD. 7 SEAT.ELEGANCE. EST.TOYOTA SUPRA MK4. RS. VAUX. CORSA.GLS AUTO. SPORT.
My car has 250,000 on the clock and new glow plugs were fitted recently, the orange light goes out after 6 seconds and starts as soon as i touch the key, instantly, no matter how cold it is. I have always made my own fuel additive which is 30% standard mineral 2T oil and 70% of cetane, circa half a litre to an 80 litre tank, this gives me smooth running and about 3 mpg more, it will also help cold starting as the cetane improves the flash point and valeancy of the fuel. Herbie.
snoman
Surrey, England
Chrysler 300C CRD 2006
  • #22
How old is the battery?
5 yrs old, almost to the day. It's a Bosch Silver, heavy duty, with 5 yr warranty and I've no reason to doubt its performance when it can crank a cold engine for 15 secs, or longer, without flagging.
Also, since the car was new, I have only used high cetane premium fuels, such as BP Ultimate or Shell V-Power, whenever available.
I regularly check for glowplug faults using an OBD2 code reader and have only needed to replace three since new.
Taffy7hfa
Oxford
Hi Snoman, that is interesting, 30 seconds is a long long time to crank a common rail diesel, near instant starting is a characteristic of these engines, long cranking times are usually an indication of a fault, most glow plugs will reach their maximum temp in less than 6 seconds, so why strain the starter and battery unnecessarily ? I get twitchy if any of mine take longer than 4 or 5 seconds.
as you say, must be something that they have programmed into the ecu for some reason.it does seem odd though.
Could your glow plug relay be playing up , that is a long start time !
snoman
Surrey, England
  • #25
There doesn't appear to be a relay. The glowplug module is connected to the battery via two fusible links connected via generator and starter circuits. Although the glowplug module does have a reputation for poor reliability, I have no reason to suspect this module as otherwise I would have been aware of a fault code. The 15 secs cranking I referred to is extremely rare - maybe once in 6 months - and which I can live with. I was really just curious about the reasoning behind the warning in the Owner's Manual of up to 30 secs cranking being required in "very cold" conditions.
image.jpg This is the glow plug relay/module I am referring to . They are fairly common for owners to replace on the om642 engine . Mine started much better when I changed it last year
snoman
Surrey, England
  • #27
I might give that a try. Can't do any harm. Had you seen any fault code prior to changing?
No , there was no fault code , no warning light registered , it was taking longer to start each week . My thinking was the car was 8 years old and the part was £115 ish which I reckoned was not far above what someone would charge to look at the car .
