Firstly - This post is about an issue with a Jeep Commander CRD, and not a Merc - But I do have a Merc, and it is a Mercedes engine
I have an intermittent problem with the engine. Sometimes when accelerating hard, or reasonably hard, then engine will very badly stumble - just cuts out for a moment and then resumes - it can do this several times in a few seconds, and always recovers if I back off the throttle. It may then repeat this right away if I accelerate again, or just behave itself for a while.
A couple of times recently when I floored it from standing, it completely died at around 3k revs and did not recover at all until I backed the throttle right off.
Also - when it is misbehaving and I quickly accelerate & back off there is a strange noise as I back off. It's a little like those turbo dump valves that some folks fit to modded cars but not nearly so loud or obvious ...
Needless to say - no fault codes at all, and it starts, and runs, absolutely fine when it's not misbehaving ..
Engine has done 110k miles with good service history
Any thoughts ?
Chris
Any thoughts ?
Chris
