bembo449
- Jan 2, 2012
- Location
- gainsborough , lincolnshire
- Mercedes Cl500, shitron dispatch
ive searched but not found what I hoped for , is this a pig of a job or not ??
yes I noted that pal , it seems a strange place to put the oil cooler to me , used to them being part of a rad pack or bolted to a lower part of the engine like of the 7 seriesIt's a long and fiddly job. I've done quite a few now. As they get older I'm finding the bolts down the back that secure all the exhaust pipes to the turbo are getting harder to remove. I don't know if this is just age or the fact that they may have been removed before. All those bolts are copper coated and are single use items. I suspect they get reused, and that makes subsequent removal a problem. If any shear off it becomes a ball ache.
What are you up to pal , you don’t have an om642 ?ive searched but not found what I hoped for , is this a pig of a job or not ??
you are very perceptive my friend . . . . or is that suspicious minded ? lol , there is a certain other vehicle that runs the OM642 that has peaked my interest of lateWhat are you up to pal , you don’t have an om642 ?![]()
Sounds like a new thread coming up palyou are very perceptive my friend . . . . or is that suspicious minded ? lol , there is a certain other vehicle that runs the OM642 that has peaked my interest of late![]()
You tease pal , details please ?I will be the owner of an OM642 equipped car once again this coming Wednesday
2 points to you , its a very strange thing when driving one , it sounds like a Mercedes and rides like an S class and if you shut your eyes you wouldn't guess what you were travelling in wasn't a high end luxury car , I just wanted something different that I can personalise a bitChrysler 300C
Think of it more as a heat exchanger than a cooler ie coolant helps warm the oil in the first place. My V6 Vauxhall had the oil 'cooler' in the same place.yes I noted that pal , it seems a strange place to put the oil cooler to me , used to them being part of a rad pack or bolted to a lower part of the engine like of the 7 series
