Om651 no boost p0045
gaylordn
W204/2011/651
How do I fix this e car is c220 no boost when flooring
onefortheroad
uk.
Me -2019 GLC 350 coupe AMG line. Mrs- 1.2 vauxhall Corsa 2021 ,orange with a black roof. .
Have error codes read and go from there. This goes for any problems in the future.
ajlsl600
france
Or buy car with no diagnostics socket!!
G
gaylordn
W204/2011/651
Switched boost pressure sensors but still the scan tool is recording open circuit. Could it be actuator
onefortheroad
uk.
Who knows ? Could be a split pipe . Did you change the map sensor ?
ajlsl600
france
No electronics, obd or any other kind of f plug in. Hence likely running costs predictable
ajlsl600
france
N if it gets wet inside its cos I didn't get roof up in time, ie my fault. Not some dh in design office organising water drain failure to run into my electronics. One may ask if that's deliberate?
supernoodle
E220 2005 2.1D
ISO description is quite clear,
P0045 Turbocharger/Supercharger Boost Control Solenoid “A” Circuit/Open.
An open circuit is an electrical fault with the device mentioned or circuit controlling it. Get the multimeter out and check supply and wiring integrity.
Suggest some searching too
tpn
S204 OM651 2012, Daimler V8 250 X 3
open circuit is electrical, either in the wiring or in the unit itself
