OM651 oil leak
CowleyStJames
Oxford
Mercedes-Benz E63s, Old knackered G wagon
My 2011 E Class 250 with OM651 engine has an oil leak at back of engine.
Any known places with these engines that are known to leak?
Thinking timing chain cover, any thoughts.
star
Reading
Smart + others :)
They leak from lots of places, seen cracked heads, rear timing case cracked from worn chain, cracked sumps, loose chain tensioner but most oil leaks are from front, oil cooler area.
star
Reading
Smart + others :)
Yes the housing and cooler are one.
CowleyStJames
CowleyStJames
Oxford
Does the oil filter housing incorporate the oil cooler? I guess it gets a coolant feed then?
Have you got a diagram, picture?
Like to understand these things
ajlsl600
france
bet thats a few bob ?
ajlsl600
france
can i ask where/why was it leaking ? O ring/gasket i would get,if made properly and fitted correctly should not be leaking anywhere else , i suppose its possible over tightening filter or stress trying to loosen could crack something ??
star
Reading
Smart + others :)
The “O” rings flatten and go hard. Not available separately.
ajlsl600
france
The “O” rings flatten and go hard. No available separately.
yr jokin ! cant get the o rings ,without buying the whole assly , i would consider that downright robbery !! and i find (no offence intended ) that really hard to understand .. .so when doing eng overhaul the seals are not in a full overhaul or top end gasket set ?
star
Reading
Smart + others :)
No offence taken, I don’t make/sell the parts. If less work was involved, I would source a replacement o ring.
ajlsl600
france
next time i get bored i will make a point of looking those seals . and keeping , somewhere i cant find em ,when the time comes to replace them. i have lots of stuff like that !!!
