Callum Davies-russell
- Jun 22, 2020
- 2008 cls 63 amg
Recently purchased a 2013 Vito 113. Day 1 it was fine. Day 2 it went into limp mode and with a generic scanner it pulled code po272. Injector 4 imbalance. Since then it has gone into limp mode with eml light about 15 times over the last 4 weeks. Sometimes it shows injector 2 imbalance, sometimes injector 4. And sometimes injector malfunction.
Today I scanned with a launch diagnostic my friend has. Injector coding is correct as I assumed this could be the issue.
Attached is the codes stored.
The only other thing that came up was oil level sensor and it says fuel pump can bus!??.
Whatever that means?
Note: injector 2 and 4 look like original items, injector 1 and 3 have clearly been replaced at some point. No signs of blow by and no black death. Top of the engine is nice and clean.
Anyone got any ideas. The van drives well other than that. I get some random drops in MPG on my commute to work. Sometimes I get 43+mpg and just before the code comes on it tends to drop to around 36mpg average on the drive home.
