Option 011 Headlight assistant?
Discussion in 'Electrics, Vacuum, Ignition and ECU' started by peterwhayward, Oct 20, 2012.
  1. peterwhayward
    peterwhayward Senior Member
    865
    3
    Oct 4, 2011
    grays essex
    Your Mercedes:
    E240 classic est 2000 2.4
    Can anyone tell me what the option above actually is?. Its in the vin decode I've got and I cant find it anywhere in the manual. Might it be the Auto setting for the lights?.
  2. tode
    tode Senior Member
    1,952
    68
    Jun 12, 2011
    NW FRANCE
    Your Mercedes:
    S350 btec 2011
    Sounds like the "adaptive highbeam assist". If so, switches automatically between high and dipped. Works well on major roads.
  3. OP
    peterwhayward
    865
    3
    Oct 4, 2011
    grays essex
    Your Mercedes:
    So that would detect a car coming in the opposte directon and dip the headlights?.Would you have to have the lights on auto for that to work?.
  4. tode
    tode Senior Member
    1,952
    68
    Jun 12, 2011
    NW FRANCE
    Your Mercedes:
    S350 btec 2011
    Yes, lights on Auto. Then make sure that the combination switch (stalk) is on full-beam: the car will then switch automatically between full & dipped.
    If you want to stay in dipped, then select dipped on combo stalk.
  5. OP
    peterwhayward
    865
    3
    Oct 4, 2011
    grays essex
    Your Mercedes:
    I will give that a try when the opportunity arises next.Hope it works though wouldn't want to "bliind" anyone coming in the opposite direction. Thanks.
  6. television
    television Always remembered RIP
    164,074
    309
    Your Mercedes:
  7. OP
    peterwhayward
    865
    3
    Oct 4, 2011
    grays essex
    Your Mercedes:
  8. tode
    tode Senior Member
    1,952
    68
    Jun 12, 2011
    NW FRANCE
    Your Mercedes:
    S350 btec 2011
    It works well, if anything it switches to dipped too often (errs on the side of safety). Will sometimes switch to dipped when it "sees" a reflective object - road sign or reflectors at road-junctions.
  9. OP
    peterwhayward
    865
    3
    Oct 4, 2011
    grays essex
    Your Mercedes:
    Thanks for the info Tode.As my post above says I'd love to have that but I cant really see someone having that fitted as a upgrade in my car which by some standards is quite a basic spec (plenty for me though).Ah well I will give it a try at the next chance I get.
  10. tode
    tode Senior Member
    1,952
    68
    Jun 12, 2011
    NW FRANCE
    Your Mercedes:
    S350 btec 2011
    I can't think what else a "Headlight assistant" would be. :confused:
    Are you sure about your "Code 011" ?
  11. OP
    peterwhayward
    865
    3
    Oct 4, 2011
    grays essex
    Your Mercedes:
    Definitely there iin the vin decode
    OPTION 011=Headlight assistant
    OPTION 024=Seats w. electr. height + tilt adjustment in front
    OPTION 069=Exterior mirror heated and electr. adjustable
    OPTION 152=Sensotronic Brake function (SBC) Hold
    OPTION 171=Exter. mirror housings w. integral ambient lightin
    OPTION 172=Precious wood finish, nutwood root
    OPTION 291=Airbag for driver and front passenger
    OPTION 292=Sidebag
    OPTION 345=Windscreen wiper with rain sensor
    OPTION 440=Cruise control
    OPTION 441=Steering column adjustable
    OPTION 471=Acceleration skid control (ASR)
  12. tode
    tode Senior Member
    1,952
    68
    Jun 12, 2011
    NW FRANCE
    Your Mercedes:
    S350 btec 2011
    :confused:
    Give it a go anyway, the next time you're out at night. ;)
  13. television
    164,074
    309
    Your Mercedes:
    The big problem in knowing what you have got is that once an extra like this becomes standard, they no longer come up on a code like 011, so I have these lights but no code as they are standard in mine
  14. toby1
    toby1 Senior Member
    4,896
    164
    Mar 13, 2007
    West Berkshire
    Your Mercedes:
    1998 CL420 C140
    Also the VIN options move on over time, so 011 might have been something else and it's being reused.
    I very much doubt headlamp assistant was available 12 years ago on a 210
  15. OP
    peterwhayward
    865
    3
    Oct 4, 2011
    grays essex
    Your Mercedes:
    Its actually the CLS (219) I'm asking about which as I say is a 2006 model. Headlamp assistant was to be available 2009 so I am a little confused.
  16. tode
    tode Senior Member
    1,952
    68
    Jun 12, 2011
    NW FRANCE
    Your Mercedes:
    S350 btec 2011
    So when does it get dark ? ;)
  17. OP
    peterwhayward
    865
    3
    Oct 4, 2011
    grays essex
    Your Mercedes:
    Just to be clear, when I put the lights to auto and then select full beam with the stalk.The blue "full beam" indicator will show, then if somethng comes in the other direction the headlights will go to dipped and the blue indicator goes off?.
  18. television
    164,074
    309
    Your Mercedes:
    If the car coming the other way throws rotten eggs at you, then you will know that it does not work :D
    My car was introduced in mid 06 and it was standard on that, the same as todes car
  19. OP
    peterwhayward
    865
    3
    Oct 4, 2011
    grays essex
    Your Mercedes:
    2006 so its possible it is that. Confusing that the article stated it was being introduced in 2009. Oh well I will give it a try and duck those eggs if thrown.:)
  20. television
    164,074
    309
    Your Mercedes:
    There might have been other things added over the basic 011 code in 2009
Share This Page
