Over heating
Londondave
2012 b class 180
Hi there I was just wondering if anyone has a clue what could be the problem with my 2012 B class 180 ,I keep loosing water ,can't see where from either,car overheats,if I don't have the car blowers on ,roasting hot in the car ,now only the passengers side blowers are blowing out hot air and the drivers side is blowing out cold air, iam baffled by it all to be honest ,any ideas what it could be would be a big help?????????
peterws1957
Lancashire
First thought - might it be head gasket failure? Any white smoke from the exhaust when accelerating?
mioba
Nottingham and Köln
second thought water pump - any noise from the engine bay when running
all a guessing game
Tony Dyson
God's Country
2014 C 220 CDI W204 OM 651
Hi there I was just wondering if anyone has a clue what could be the problem with my 2012 B class 180 ,I keep loosing water ,...
Has someone replaced/significantly topped up the MB spec coolant/antifreeze/inhibitor mix with plain old water? Especially the muck delivered in London! :eek::)
L
Londondave
2012 b class 180
Nope no smoke or gunk first thing I checked
Sent from my SM-G996B using Tapatalk
L
Londondave
2012 b class 180
Yes this silly person would have done that
L
Londondave
2012 b class 180
all a guessing game
No noise from engine ,weird how all the heaters in car where working but now only passengers side is only side working now
With engine cold squeeze the top hose.
Run engine 3-4 minutes.
With engine running squeeze hose again.
If it's rock hard head gasket has failed.
L
Londondave
2012 b class 180
No bad smells,no white gunk in oil filler cap ,hose one side is soft and hot and other side is cold and soft ,it's weird mate honestly ,I could be pouring money down the drain with this one lol
Check carpets in front footwells.
Lack of heat could be an air lock in the heater circuit.
If all else fails get some UV dye and add it to the coolant then shine a UV torch about looking for the tell tale.
UV dye kits are available online for not much money.
