P0103 maf problems on c180k 271 pin1 on maf ?
Discussion in 'Engine, Drivetrain, Fuel and Exhaust' started by billyc180k, Nov 9, 2012.
  1. billyc180k
    billyc180k Senior Member
    54
    Jan 27, 2011
    high wycombe
    Your Mercedes:
    C180k/2002/1.8komp
    Throwing the code open circuit short to positive, checked wiring on pin 1,3,4 to ecu all fine and have battery voltage on pin 2 which is shared with the upstream 02 sensor (green/red) when engine is running i have 14v on pin 2 and 12v on pin 1 is pin one ment to have that ? The code erases but come strait back on when engine started also i have no oil in connectors and have replaced engine breather pipe under manifold ? Any ideas thanks
  2. Steve@Avantgarde
    Steve@Avantgarde Forum Supporter Authorised Forum Supporter
    6,825
    1,003
    Dec 8, 2009
    Bristol/Somerset
    Your Mercedes:
    C220CDI AMG Line Premium, SLR McLaren Roadster, SL55 & C32AMG
    Stretched timing chain more likely the cause.
    The fault codes can lead you up a right garden path as the variable timing fault can cause it to run strange emmisions values.
    If I were you before you waste anymore time going into electronic tests, whip the rocker cover off and time up the engine. I bet its a tooth out on the inlet cam.
Share This Page
