Paint codes / colours for r129
dt4
Leeds
SL320
I would like some touch up paint for my 1994 R129, is the paint code info on the car VIN plate or else where?
In particular I would like to get hold of the paint for the bumper / side trim.
thanks for any help / advice
David
D
dt4
Leeds
SL320
Thank you both, Ill get the chasis number
D
dt4
Leeds
SL320
just realised it was close to hand
WDB1290632F098699
Cheers
Richard Moakes
Newton Abbot, Devon, UK
CL500; ML500
The main body colour is paint code 744 (Brilliant Silver)
The lower body panels are paint code 7181 (Atlas Grey) with a satin lacquer
The satin finish is standard 2k paint with 10% matting agent added, and that is undetectable from the original.
D
dt4
Leeds
SL320
Thank you
Ljschalm
Medford,MN USA
500sl/1991/5.0
PAint Code for 1991 R129
I just joined the forum and seek the codes for the lower body panels.
My VIN is WDBFA66E1MF016819. The main body code is 702 but I cannot locate the lower code.
Any help is greatly appreciated!
Thanks, Les
I believe that member "grober has the codes for the lower panels, lets hope he see the post, just for reference there is a 10% mating agent for these panels.
WDB124066
1996 E320 Sportline Cabriolet X 2
Yes there is, be careful they don't "matt" it too much because the less gloss you have the harder it is to take off the bugs without leaving a stain. A little bit more gloss is your friend - on the front bumper at least.
You do have a good point there as the original paints can no longer be used, they were much harder.
Richard Moakes
CL500; ML500
For chassis number WDBFA66E1MF016819
The main body code is 702 (Smoke Silver)
The trim panels colour code is 7176 (Mussel Grey) with a satin lacquer
mandarin4000
500sl 1993 V8
Can you please look up my paint codes
WDBFA67E4PF080081
mandarin4000
500sl 1993 V8
Can you look up my paint codes
WDBFA67E4PF080081
