Hello there! Ok recently I put up a thread and had some good advice back about my wings. They were all in a poor condition. I have since then, rubbed them back, got rid of the rust, treated it, filled the areas and primed them (3 coats). I have then used a fine wet/dry over those areas ready for painting.
Using the Halfords Mercedes Black rattle can, I went over the arches (and just above where the rust was) and done about 5 to 6 coats. As the weather was overcast and around 10c at the time, it produced only slight orange peel. From advice from here, I let it dry for a few days, then rubbed it down with fine wet and dry paper which left a dull shine.
Ok now this is where I need help. You can see where the old laquer ended and the new paint has that dull shine. Using T-CUT black and a machine, I buffed all the wings and the new paint come up nice, but it is obvious that with no laquer over the top of it, it wasn't going to blend in. Also the new black isn't as dark as the old black, this could be due to no laquer.
Now, should I have rubbed them down, then sprayed the laquer and blended, or sprayed the laquer over the freshly painted areas then blended without using wet and dry? I had to use the wet and dry due to the slight orange peel but should I have then spray over the laquer, or do you compound to bring up the new paint then laquer?
Sorry for the questions :cry: I really want to get this right. I have bought some stronger rubbing compound from halfrawds now and the guy said there to mix with the t-cut to get a feathered effect with the laquer.
Thanks in advance,
Matt
Thanks in advance,
Matt
