Panel remove
Hewe
Registered
B180 se cdi
Hi all I would like to fit a dashcam but don’t want wire’s.hanging ,at the same time I don’t want to damage trim.i have a b class 2014
Hello and welcome,
With some plastic trim tools you should be able to remove the A-Pillar trims and hide the wires behind them.
EmilysDad
Bury Lancs
ML350
when I've fitted dash cams, I'm managed to tuck the wires in under the edge of A post trim without completely removing them, likewise the head lining.
Srdl
Hampshire
GLC43 AMG 2018 (X253)
Same for me. Go across the top of the A post, tucked into the join and then down the door opening under the rubber. On some models, there is a panel on the end of the dashboard which you can access when the door's open. You may find fuse box or power supply in there as well.
