Parking brake ratchet...
Dosco
W211
...appears to 'miss' a couple is it easy to replace - suspect the teeth have rounded or simply worn away?
Roger
Hertfordshire Merx
A160
If its just the noise side of things that has stopped working then its items 14 and 17 that you will need.
D
Dosco
W211
It seems to fail to 'catch' as if the first few teeth are damaged/worn but pushing down harder and it will 'catch' okay - however you are right in that the 'noise' side of things does appear to be missing = if you see what I mean!
sorry I forgot,its an age thing:Oops: I will do it today
I turned the computer off 10 secs before you posted, but I have saved the post for when I turn on later
4 papers sent :D:D
I have just read all of the papers and it is as Hertfordshire Merx said. its only a friction device
