Parking Brake Sensor
hawkinsd
BASINGSTOKE
W203 220CDI 2005
When i release the parking brake the brake on alarm sounds when i drive away even though the brake is off. Is there a switch or sensor that i can adjust its postion?
Cole@MBS
www.mbssouthampton.co.uk
Lift up the rear seat, in the middle on the floor you see a small black cover, remove, there you find the handbrake cable spilter, lube up as much as you can while somebody works the handbrake on and off, it will soon free off!!!!
H
hawkinsd
BASINGSTOKE
W203 220CDI 2005
thanks but sorry if i did not explain the problem well. The brake actually releases fine but i have to with my foot under the pedel lift up the pedel several times to stop the bleeping alarm. the pedal down sensor must be out of position, any thoughts
What is the car please
I have sent you 2 papers showing where things are,
The first thing to do is to lubricate all of the linkage that goes to the rear brakes, oil them all move them as you go and then see. make sure that all parts move freely
H
hawkinsd
BASINGSTOKE
W203 220CDI 2005
I lifted the rear seat, do i need to rip up the sound insulation that is stuck down under the seat or am i looking in the wrong place?
Never been asked this, you only need to get to the panel in the center towards the rear of the seat
8thumpers
Shropshire
www.atarukarate.co.uk
I have a similar problem on my ml 270 cdi - warning alarm beeper sounds with brake light on and all 3 abs/traction amber lights too. Just changed the pads to no avail. I assumed that a pad sensor was touching the disc but they all were well away from any wear surface.... any ideas?
Cole@MBS
Last time i see that it was the ESP/ABS control unit gone down, lot of money to replace!
www.W140.co.uk&www.r129.co
