Don Boser
- Jan 24, 2020
- 2011 ML 350 3.0 litre diesel
Dear Forum,
I am a new member and my wife recently had a fender bender and I hadn’t checked the car thoroughly after the repairs were made . I noticed that as soon as she went to leave the garage, the red lights flashed on the Parktronics. I cleaned the sensors but no change. I used a Scanner and noted that all the sensors were reporting low voltage. I then removed sensor and cleaned the connectors with electro clean. I noticed one sensor had two wires that were spliced and the third one was simply rapped with electrical tape. My question is could this wire harness repair cause a fault on both the front and rear Parktronics sensors? I also noted that if I remove one sensor completely the whole system goes black with no lights lit.
Any feedback would be appreciated!
