pasenger door window wont work (audible click) 420sel ?
smarty
having cleaned all the fuses, replaced window regulator (comfort diode) all widows were working fine, however! just noticed the passenger door window will not function, stangely though you can hear an audible clicking sound, whilst driving and parked, the key is in either position one (1) or two (2) the sound is definate, as though something wants to happen but hothing! i dont think its anything serious cause they were all working before, any ideas lads?
Is the clicking in the door,,there could be a thermal overload cut out working
smarty
yes malcolm, its in the door.
I think that you must take off the liner and check the motor as it appears to be stuck,,a clout with a mallet may free it off, the motor that is
smarty
thanks malcom, im glad you said the motor! is that what you think it is, mind you, sounds logical, because the clicking does sound as though something is trying to work, ive never had to take a door card/trim off anything to watch out for? also an additional quickie is the torque setting for the 420/126 the same at 110nm? ive just got some cracking original wheels.
I may have some door card removal instruction,,and I will post back,,the main thing is not to damage the card where the clips hold it on.
Yes the 110 is correct for your nice wheels
smarty
thanks malcolm, ill hold on till you post if you have any details, much appreciated ill check back later im bidding on ebay!
Never bid till the last 10 sec of the auction;):D
smarty
got myself some loverly centre caps, to match the badge on the grill, your right about the last ten seconds though! lost a couple of potentials, live to bid another day, did you have any info Malcolm?
I have the details for you I need an Email address
I have sent it,, you can go back and edit out the address in your last post
smarty
thanks for that Malcolm, i take it even though mines the 420sel the instructions are across the board and very similar, and rule of thumb is take care and dont rush it eh!
The principle is the same,,as before when you prise off the clips,,make sure that you lever the clip and not the card,,the clips cost peanuts if they break
II use a special flat blade with a V cut in the end that goes over the plastic clip
smarty
good idea, like a 2" wide scraper with the "V" spread the load and the preasure, nice one.
Thats correct, the V goes into the round clip and pulls it from each side,,they are sold for around £5
