greenfingers
- Jan 14, 2007
- Location
- North Oxfordshire
- Previously:- ML270, 3 x Vito Dualiners, SLC450
My electric mirrors adjust fine.
My memory seat remembers it's position fine.
My memory passenger mirror remembers it's normal driving position fine; however when I select reverse, it develops amnesia!
Instead of moving down and in to it's correct setting, it goes up and out!
I have reset it numerous times and it works correctly for a bit, but after turning off the ignition, it seems to lose it's memory and go up and out again.
Someone here pointed out that if you leave the right mirror adjuster selected, then the passenger mirror does not move into it's reversing position. This is true, and normal reversing is now possible (at last!).
I have been setting it according to the handbook, and presumably that is right? Has anyone else had this problem, and is there a solution?
