Performance problem after B service
E320_CDi
Guys... After some advice. I've just had a B service done today, on my yr 2000 e320 cdi, indie changed the fuel filter, air filter, oil and oil filter, checked the car all over.
For some strange reason, the car isn;t performing as it was before the service, it doesn't seem to be accelerating much, and seems as though its changing gears a lot quicker. It's picking up speed, but very slowly. Any ideas?.
Does something else need resetting after the B service, or after the fuel filter is changed. Any help / advice would be greatly appreciated. Will also take it back to the garage on Monday.
thanks
Its not been switch from S to C on the box or something simple like that has it!!
E
E320_CDi
SAM/UNIT.
Reply: Hi.. Car is running on auto, W on the switch, thanks.
TEDDYCATKIN.
You did not use a MB dealership by any chance ?
Reply: Hi.. I used an independent garage, my firends, who's been in the trade for around 19 years, and I always trust his work.
Midland45
SAM/UNIT.
TEDDYCATKIN.
Should it not be in S summer/standard, W i thought was winter mode, now labelled as C comfort mode. In C mode my W209 doesnt seem use 1st gear and I suspect gear changes are at lower revs.
Put the car into the S and you should find it better, maybe as it was
E
E320_CDi
Performance problem
Hi.. Can't understand, the car was always on W. Something which I've noticed this morning, there's no kickdown either, the pedal goes to the floor, but no kick down.
thanks
I think that some pipe or something has not been joined up,,you will have to go back and get him to check things
A
andy@pcd-ltd
Hi
There is a chance that he may have left the mass air flow sensor unplaugged when they changed the air filter.
I would check this first and also see if there is any fault codes stored in the ecu
E
E320_CDi
Thanks to everyone, I'll get the MAF and pipes checked in the morning.
E
E320_CDi
Thanks everyone, problem sorted. Went to my mechanic, and just like someone suggested in their reply, looks like a pipe or cover had not been replaced, power is back, with a vengeance !!!!! :)
