I have petrol leaking in a steady stream from all 4 injectors ( from the white plastic bit ) when the car is cold , and it stopped when hot ???
does anyone has a clue????
thanx in advance
K - South africa
you have same problem as me,sounds like your seal washer has cracked,reason it stops when running because,it,s not leaking when fuel is passing through,due to exspansion, i can,t get the injectors Out ? any ideas
cheers col
Comand Online Ltd is a specialist supplier of Mercedes Navigation Disks,
Phone & Bluetooth, iPod, DAB, CD and other COMAND retrofit parts to
enhance your vehicle.www.comandonline.co.uk
