Petrol smell
BJ1
Milton Keynes
2003 E270 CDi Avantgarde
Hi, I have a 98 C180 Sport Estate, I have a smell of petrol when I fill up.
There is no leak as I constantly check, the smell will be there if I put half a tank or a full tank.
When the fuel goes down to a quarter the smell will go (well almost).
Any ideas?
Cheers
Brad
SQ_W211
W219 CLS55 AMG
I had a minor leak once and was advised by someone to do this.
http://forums.mercedesclub.org.uk/showthread.php?t=49245
Give it a go as the only reason for a petrol smell is if its getting out of tank somehow and from what you saying, it seems the problem goes away when the petrol level goes lower so it could the pipe which connects to filler cap.
You could look around the filer pipe for any damp patches, they will look black looking area's, if it is not there all the time, then cannot be fuel pipes
roofless
w124 e220 estate
if it's at the top of the fuel filler pipe you would have a strong smell inside the car esp the estate model
Xtractorfan
S class
These cars do have a charcoal filter..under the wing?? This is designed to absorb the fuel gasses and smells, the filter may need changing or a pipe may have become perished or frayed...
SQ_W211
W219 CLS55 AMG
Thank you Xtractorfan for a very informative Post
B
BJ1
Milton Keynes
Cheers for the filter info and all the other advice, will check out this weekend and let you know the results.
Thanks again all
Cheers
Brad
