Please help..Kickdown not working
Discussion in 'Engine, Drivetrain, Fuel and Exhaust' started by markdenning, Aug 5, 2019.
  1. markdenning
    markdenning Member
    10
    May 28, 2019
    Your Mercedes:
    58reg.eclass 280 cdi sport
    Hi all..i hope u can help..im panicing,had my car since june 2nd..all was fine,but today on my into work,kickdown didnt work..working fine for abt 2mile..turned the car off and it worked ok for abt a minute then wudnt work..works ok in manual...please help chaps
  2. LostKiwi
    LostKiwi Senior Member
    18,415
    8,564
    Aug 25, 2006
    Your Mercedes:
    '93 500SL-32, '01 W210 Estate E240, 02 R230 SL500 (Malcolm Spec), 04 Smart Roadster Coupe
    You need to get codes read - without codes being read we'd just be guessing.
  3. OP
    markdenning
    markdenning Member
    10
    May 28, 2019
    Your Mercedes:
    Wud the codes show on the dashboard??
  4. LostKiwi
    18,415
    8,564
    Aug 25, 2006
    Your Mercedes:
    No. Needs a Star or similar code reader.
  5. OP
    markdenning
    markdenning Member
    10
    May 28, 2019
    Your Mercedes:
    Im gutted..as ive sed only had it 2months..had a bad thunderstorm last night so im thinking cud be water getting in somewhere!!thanks again for ur advice...
  6. LostKiwi
    18,415
    8,564
    Aug 25, 2006
    Your Mercedes:
    If you bought from a dealer take it back.
    Under the consumer act they have to give 3 months warranty.
  7. OP
    markdenning
    markdenning Member
    10
    May 28, 2019
    Your Mercedes:
    Is that right?it did say on the advert it had 3months warranty,then i paid £120 to put some kind of warranty on also)think i was mis-sold that if im honest..i guttedas i love the car,but the wife will go mad wen i tell hershe thinks car run forever without any problems...
  8. umblecumbuz
    umblecumbuz Senior Member
    3,647
    998
    Sep 20, 2010
    Wales and Gozo
    Your Mercedes:
    S204 and CLC 204 cdi, other non-Merc machines
    Check to see if your cruise control has also stopped working.
    The two symptoms are often related, and can give clues as to the cause.
  9. Gazwould
    Gazwould Senior Member
    566
    218
    Oct 28, 2018
    Your Mercedes:
    S204 OM651
    It's 6 months with consumer rights act .
  10. John Laidlaw
    John Laidlaw Senior Member
    20,160
    5,498
    Nov 15, 2013
    Wirral
    Your Mercedes:
    UnMercs BMW i8 Volvo XC90
    You haven’t accidentally set the speed limiter have you?
    If not, as above get it back to the dealer especially as you’ve paid some kind of extended warranty ...
  11. EmilysDad
    EmilysDad Senior Member
    7,385
    1,347
    May 8, 2012
    Bury Lancs
    Your Mercedes:
    ML350
    Kick down should over ride the limiter
    ..... it did on my R Class though I've not tried on my ML.
    sl500amgsport likes this.
  12. Blobcat
    Blobcat Moderator
    14,497
    3,452
    Near Grange Moor (not Wakefield...)
    Your Mercedes:
    R171 SLK280 3.0, Land Rover 110 County SW
    It does but you have to press a long way past normal to do it.
    John Laidlaw likes this.
  13. Altamar
    Altamar Active Member
    28
    22
    Dec 28, 2018
    Your Mercedes:
    2014 E Class 220D saloon & 2015 SL400
    I stopped reading when I got to this point! You have at least one if not two warranties so get it back to supplying garage asap - oh, and then post the result here please so that we all know what the problem was once it is fixed under warranty!!
  14. OP
    markdenning
    markdenning Member
    10
    May 28, 2019
    Your Mercedes:
    On my home from work ive noticed the check engine light is on...car seems to be under powered..cud that be limp mode ive heard of?engine runs ok no strange noises ,gears r changing up and down.just no get up and go...pressed the go faster pedal and it just builds the speed up gradually..still no kickdown..its in the garage on wednsday.so im using the wifes car just in case..thanks again..
  15. LostKiwi
    18,415
    8,564
    Aug 25, 2006
    Your Mercedes:
    Yes that sounds like limp mode. I'd hazard a guess at the conductor plate in the gearbox but it could be several things.
  16. OP
    markdenning
    markdenning Member
    10
    May 28, 2019
    Your Mercedes:
    Just been informed by garage..computer says it a lamba sensor £120 for the part!!!awaiting reply from warranty people for the go ahead
    LostKiwi likes this.
  17. Blobcat
    Blobcat Moderator
    14,497
    3,452
    Your Mercedes:
    Best of luck :)
  18. OP
    markdenning
    markdenning Member
    10
    May 28, 2019
    Your Mercedes:
    Finally got my car back today..the warranty is a waste of paper as is the garage i bought it off..loads of emails back and forth between both parties and got messed abt..finally got the go ahead to fix the lamba sensor only to receive another email from the warranty company saying they wud only pay £90 toward the bill..which is £210,garage i bought it off it not answering and calls,txts or emails im off out in the car for a bit..thanks for all ur help
  19. Blobcat
    Blobcat Moderator
    14,497
    3,452
    Your Mercedes:
    Sorry to hear of your woes but it’s fixed now so go and enjoy it.
    This is why I don’t buy any extended warranties as I’d rather not have the grief and stress of arguing with them.
  20. davemercedes
    davemercedes Senior Member
    2,476
    654
    Jun 15, 2012
    Worcs
    Your Mercedes:
    2007 Merc 220 CDi Est Auto Av
    These extended warranties are such a minefield and it's really luck of the draw. I bought SWMBO's car (an 05 ex-Mobility Renault Grande Scenic) about 10 - 12 years ago from a semi retired car sales guy who worked from home. Price was good and he gave me what I asked in PX for her old car. As an afterthought I asked about extended warranty and his opinion was more or less the same as yours.... But he sold me a warranty policy at his cost "just in case". Six months later the "heads up" LED dashboard died totally. I took it to a Renault main dealer who happily billed the warranty company who paid in full and I certainly got my money's worth.
    She still has the car and it start first time and costs me a road tax bill, and insurance premium and a "check all levels" service once a year.
Share This Page
