helljcat
- Apr 13, 2009
- Location
- St Neots
- Merc 320 CLK Cabrio Avantgarde
For the grand total of two weeks I have been the proud owner of a 2001 w208 320 CLK cab. Only 45K on the clock and a full merc service history.
However so far the following faults have appeared:-
CPS replaced
EC light staying on (managed to clear the fault code but worried will happen again)
Drivers memory seat lost all settings, reset and now remembers them
And the best bit.....went for drive today and a worrying noise (knocking noise) developed under hard acceleration (no loss of power). It is now noticeable on idle and appears to be coming from under the car in the area under the drivers seat.
Two questions you gurus maybe able to help out with:-
Is the knocking likely to be the cat?
As the car is under warranty I will give the garage a chance to fix, but losing confidence that more things wont go wrong.Thinking of asking for money back. From the above does it sounds like I have a case?
Many thanks for any help! ( I have also posted this on the general forum.)
CPS replaced
