Pooky
- Sep 5, 2020
- E320 CDi
I ran my W210 E320 (79,000 miles) out of fuel for the first time last week (was idling the engine to warm the car up and it just died) As my E300 TD fuel gauge would completely bottom out before running out of fuel I didn’t immediately consider fuel starvation so spent a good couple of minutes intermittently trying to start the car. Eventually I stuck five litres of diesel in the tank and after a further good couple of minutes cranking, the engine finally sprang into life.
All very well, I hear you say but since then cold or hot, the engine has required a good 1-2 seconds of cranking to start whereas previously you didn’t hear it cranking, it would burst straight into life as soon as the key hit position III.
I am now wondering whether the prolonged cranking on an empty tank has somehow damaged the rear fuel pump by drawing air into it. I believe that these pumps rely on diesel as a lubricant. It could be air still in the lines somewhere, but I think this unlikely as the car has run for over an hour and about forty miles since being restarted and when kicked down, it still pulls strongly without any hesitation.
Any thoughts? I know a lot of cars will crank a little before starting but this one has never not started instantly, even at -12*C on a depleted battery so something has happened.
