benzy007
- Nov 12, 2010
- Location
- London
- C180 Saloon, 2001 petrol, manual
Hi Guys,
This is a new problem I'm having after my recent engine overheating issue as discussed in this forum.
Problem with the key initially started about 2 months ago, but it was not bad at all in the beginning so I ignored it thinking the battery was low in the key.
My car locks/unlocks fine with the remote key fob at all times.
When I put the key in the ignition, its not always recognised.
It fails to turn, fails to even unlock the steering, also fails to make a zaap sound when key inserted.
Its got so bad within the past couple of weeks that it would happen about 25 times a day (almost everytime I wanna start the car).
After fiddling around taking the key in & out a few times it would work.
It eventually got so bad 2 days ago it failed to turn at all.
Tried for over an hour, no luck.
I looked for a spare I had, I found it 6 hours later thank God.
Car worked fine with the spare without any problems whatsoever.
The spare key initially failed to lock/unlock the car but started fine, the red light was not flashing, so I changed batteries over now everything worked with the spare.
However, I've started to experience the same issues with the spare key now.
The car battery is good so I can eliminate that from reading other posts on the internet.
I tried the camera thing to see if the light flashes, the spare key does flash, but the 1st key which completely failed doesn't.
Any help much appreciated.
