Preglow plug - where do I buy from + guide to change
Discussion in 'Engine, Drivetrain, Fuel and Exhaust' started by OM2, Nov 25, 2012.
  1. OM2
    OM2 New Member
    5
    Nov 25, 2012
    Your Mercedes:
    E320/2005/3 litre
    My first post here!
    I've purchased a 2005 E320 auto diesel
    The preglow light comes on and stays on for exactly 90 seconds before going off after starting the engine
    I've googled and seen a video or 2 on youtube
    Where do I buy from?
    I've googled but can't seem to find a single result!
    Can someone give me some pointers? Obviously I must be searching for the wrong phrase
    Guidance on how to change: I'd really appreciate if someone could point me to my specific model
    ALSO... I've read that the best option is to get an OBD2 unit and use to test and find out the faulty preglow - else you have to take out turn on and repeat until you find faulty one. Is this correct? Will I be OK using a bluetooth OBD2?
    OM
  2. peterwhayward
    peterwhayward Senior Member
    865
    3
    Oct 4, 2011
    grays essex
    Your Mercedes:
    E240 classic est 2000 2.4
    Welcome to you OM2."Knowing all" about any type of car is a big task it seems from the outside (me knowing nothing) that even the people that have devoted their lives so far to car repair and maintenance, still on many occasion are "perplexed" as to the answers. But good luck to you anyway.
  3. Ginno78
    Ginno78 Senior Member
    65
    Nov 8, 2006
    South Wales
    Your Mercedes:
    2005 E320 CDI V6
    Just a helpful tip...Mine did this, and after changing all 6 glow plugs it was infact the Glow plug relay at fault
  4. Ginno78
    65
    Nov 8, 2006
    South Wales
    Your Mercedes:
    2005 E320 CDI V6
    I had 6 Beru glow plugs from Eurocarparts for about £60 with discount code
  5. Remenham
    Remenham Senior Member
    133
    Jan 16, 2012
    Bolivia
    Your Mercedes:
    a140
    If you do a search on e320 glowplugs or just glowplugs on this site you will find masses of information. Did so recently myself after my light started staying on.
  6. OP
    OM2
    OM2 New Member
    5
    Nov 25, 2012
    Your Mercedes:
    E320/2005/3 litre
    thanks for the replies guys
    not guilty: how am i supposed to know that i'm supposed to search for 'glow plugs' instead of 'preglow plugs'
    lol
    @ginno78, the car has done 94,000 miles now
    i have no reason to think that any of the preglow plugs have been replaced
    i really don't want to fork out for all 6
    but is that like saying "i don't want to spend money doing a service?"
    discount code? where do i get this?
    @Remenham: found it on europart website now - thanks
    @peterwhayward: yes, absolutely agree. better to be a master of a subset than be a jack of trades in everything. i really want to get into diagnostics for modern cars. happy to invest time and effort becoming an expert in this field. just don't know where to start...?
  7. REMEmechanic
    REMEmechanic New Member
    9
    Nov 26, 2012
    Somerset
    Your Mercedes:
    C250td sport estate 1998
    Hi there, the symptons you describe point to a single glow plug only. I am not familiar with the E320 (I have the C250Td) but imagine it's fairly similar, therefore you will need to remove the manifold to gain access to the glow plugs.
    Pull off the electrical lead, it will be tight (it's a press on fit) you will need an extra deep socket to unscrew the glow plug, you will have to remove one glow plug at a time to see which has failed, simply remove it, re-fit the lead and rest it on the head, then turn the ignition on, the end should glow red after a few seconds...if it doesn't then replace it.
    Once replaced with new re-check to see if it glows red (if you don't have a new one just remove one other from the head and try that!
    If you do find one that is faulty and replace it MAKE SURE that the dash light goes off as well just in case there is more than one faulty.
    Advise just going to your local motor trade shop, they are usually best and cheapest, completely pointless changing all 6 when it's probably just 1.
    Regards
    Russ
  8. Frontstep
    Frontstep Senior Member
    7,416
    1,302
    Apr 22, 2007
    Your Mercedes:
    T210 320cdi
    Removing the big engine covers black and silver will reveal the glow plugs you can test them with a multimeter.
    There are many threads on here, read as many as you can and do a google images search.
    If you are reasonably competent with the tools its not a hard job but a heavy handed approach can cause many problems.
  9. mikestrivens
    mikestrivens Senior Member
    2,715
    146
    Nov 21, 2008
    Stockport
    Your Mercedes:
    this has been answered in your other thread
Share This Page
