Problem resetting trip recorders
Discussion in 'Electrics, Vacuum, Ignition and ECU' started by Beemer2, Oct 17, 2012.
  1. Beemer2
    Beemer2 Active Senior Members
    138
    Oct 7, 2012
    South Lanarkshire
    Your Mercedes:
    2014 E250 petrol W212
    Today I tried to reset the trip recorders for the first time. On doing so both read 0 but when I came out of those menus to the "trip" view the trip figure (not total mileage) still had the same reading. I had to repeat the process four times before I got a zero reading. Was I doing something wrong?
  2. Troon
    Troon Active Senior Members
    917
    3
    Sep 16, 2011
    Staffordshire
    Your Mercedes:
    A big one
    I don't know the W212, but on my 211 the trip meter is separate from the "from start" and "from reset" counters, and needs to be reset when the screen is not showing either of those counters.
  3. OP
    Beemer2
    138
    Oct 7, 2012
    South Lanarkshire
    Your Mercedes:
    So why three recorders?
  4. drmw
    drmw Moderator
    3,683
    112
    Nov 25, 2007
    Yorkshire
    Your Mercedes:
    one for the current journey - the car decides when it will reset.
    Then two separate trips that you reset as and when
  5. television
    television Always remembered RIP
    164,074
    310
    Your Mercedes:
    I have an overall trip and another that I can use for trip that I may need the info on.....I leave the main one as is so far, and when I did a 300 mile journey, I used the other
Share This Page
