Hello i am not sure if i am in the correct forum but i hope someone can help. My fan was not working and the car overheated if running at a stand still. I tested bridged the connection on the thermo switch with the ignition on and the clutch engaged. however whilst doing this i noticed 2 pipes that have snapped from the same area. The pipes look like straws with rubber hooks on the end. Please can some one explain what they do and what i need to buy to fix the problem. Also will there be any dammage caused if i continue to use the car untill i can fix it thanx. Please see the pics. P.S I taped the pipes up so they wouldnt drop under the engine.
