KathKeen
- Jun 13, 2012
- Location
- West Sussex
- C220, 2002, diesel auto
Hi all, hoping you can help.
My C220 2002 model, has recently been keeping in the same gear, when I get to a certain speed, from start to about 30-35mph, the gears change fine, then when I put my foot down on accelerator, to the floor "pedal to the metal", nothing happens, doesn't change gear, just slowly increases speed with no gear change. When you put your foot to the floor you expect the auto to change down gear to attempt to reach the speed you require, but nothing.
There is no indication on the dash to suggest it is in limo mode.. When in limp mode does a light come up on dash? There are no other warning lights?
Could my trans fluid be low? I have also read MAF could be the culprit. Is there anything else it could be? As I say, it does not say its in limp mode.
Also, couple weeks back, the gar wouldn't come out of 2nd gear, it just kept revving the faster I wanted to go. I stopped turned car off, then restarted and its been fine since.
Only prob now is the not changing down gears to accelerate successfully.
Many thanks for your help if you can!
