L
Lukey1991
Hello,
Im new to the forum and Just wondered wether somebody would be able to help me on this as Im not the most technically minded. and this is not an abvious fault.
The problem is where the Passangers door on my 2006 Mercedes CLK 220 CDI Avantgarde Automatic Model: C209.
The Passangers Door Doesn't Seem to be getting any power, I say this because the window will not go down buy the master switch on the drivers door and neither by the passangers door switch, also to add to this it will not lock or Unlock by the remote central locking. The only doors that lock are the Boot And also The drivers door, but nothing from the passangers, now also the passangers door mirror cannt be adjusted neither will it fold in (but the drivers door does) the passangers door will lock when you push the pin down from the inside of the car and you can only open from inside by bpulling the handle.
I hope someone could help me here.
