Problem with the CLOCK in the instrument cluster. w212
Oktay96
w212 E350 BLUETEC
Hello everybody!
I have a problem with my clock in instrument cluster the car is 2012y w212 E350 BLUETEC DIESEL engine and it's made for US i have new battery S5 BOSH AGM so it is not because of low voltage ,but i have been in so many mechanics even they can not find a solution for this proble does to anyone happen something like this?
Not_Anumber
S212 E350cdi prefaclift
Is the time on the command/ system central display correct or does that also keep changing ?
I will be interested in following this as though the clock in my S212 is not spinning ther is a 1 hour difference between it and the system time which i am trying to find a cure for.
Botus
S500/2010/500
what DATE does the car think it is - even that might be misleading if you haven't disconnected the battery since May 2019
satellites rotated their dates in a muddle up of a 19 year cycle and nasty programming in april 2019 - thus your car no longer knows what year it is - its most obvious to the end user where it muddles daylight saving
there may be a software update to fix it....
Not_Anumber
Mmm food for thought there. Mine shows a completely nonsense date, from memory something that's several years before the car was made. Is it recommended to disconnect the battery for a while to get it to resync from satellites ?
Botus
S500/2010/500
...then it needs a software update BUT its look like Merc never bothered to make it for your car
there is no such thing as reset or re-sync - satellites beam out the time and date continuously and the car see it the split second the comand is on - for no good reasons many systems then pretend they need to wait - like Noika built in 20 min delay to make you do a data connection so they can spy on you etc.
its entirely due to the usual 19 year WNRO rotation - your car is now unable to make sense of the info the satellites beam out, the ONLY way this can be resolved is via updated software added to each individual car - my 221 had the same issue (like most Mercs - some - and I suspect W213's got a late 2019 software update - go to services menu, left nudge and hold the comand knob for 10 seconds and you get a choice of epoch's to select - choose the correct 19 year cycle and everything goes to normal)
For the W221s a USA guy reverse engineered an update disc and wrote updated code as Merc couldn't be bothered.... (then Merc adopted his work - I added the two systems Merc forgot they made on a later disc - like everything these days no one has a clue - its deliberate).
Botus
S500/2010/500
Hello everybody!
I have a problem with my anoluge clock spinning out of control [/MEDIA]
an interesting idea would be to deselect daylight saving and see if the two clocks align....
when (if) they align but to the wrong hour, selects a different country (Belgium should then take you to english BST - for this time of year) and you can swap back to UK in the winter - its crap and your time of arrival will be 1 hour wrong
another post about their clock being 3 mins out is a related issue as the clock is muddled - here disconnect the vehicle battery at 11:58 and 15 seconds before midday / midnight reconnect the battery and it will spin to midday they try cross ref real time from satellites - as it won't find them. it will just carry on. But the 3 min lag bug will be gone for a year or so
O
Oktay96
w212 E350 BLUETEC
I will be interested in following this as though the clock in my S212 is not spinning ther is a 1 hour difference between it and the system time which i am trying to find a cure fЪе
Yes the time on command/system is correct and it never changes.
O
Oktay96
w212 E350 BLUETEC
I have just bought a brand new battery BOSH AGM S5 like 2 month ago ,but even with old battery it was the same.
O
Oktay96
w212 E350 BLUETEC
Thank you so much for helping me to find a solution i will try with software i live in Bulgaria but car has been produced for US market i will find someone to do it for me maybe if there is EU version so this is the first thing i will do right now!
O
Oktay96
w212 E350 BLUETEC
It is a good idea ,but sound difficle.
Botus
S500/2010/500
ticking a box in a menu within comand should be easy?
on mine you go to region - select your country - and then next step is "do u want daylight saving" tick yes or no
O
Oktay96
w212 E350 BLUETEC
I set off the day light options ,but the clock does not stop spining.
V6Matty
Newark, Nottinghamshire
It has to go around the full 24 hours I think to sort itself out, takes a little while and is kind of unnerving
O
Oktay96
w212 E350 BLUETEC
it stops for while but on wrong time then it goes again.
sonic
Staffordshire
E350CDI, SLC250d, FJR 1300
Being made for the USA market is it set up to see Euro satellites, or would a software upgrade sort that?
Botus
S500/2010/500
pretty sure satellites are satellites - a cruise missile won't be much cop if it gets lost half way to see putin? or maybe that why we needed them at greenham ;)
@Oktay96, u spotted the date is all of a mess, maybe your model just spins the clock - that way more likely to get you to a dealership to spend some money ;)
WNRO a STANDARD event in satellite world where they expect them to die after 15 years, so only had a date that lasted 19 years,
1st rolloverAugust 21, 1999; 22 years ago1
2nd rolloverApril 6, 2019; 3 years ago7
3rd rolloverNovember 20, 2038; 16 years' time0
4th rolloverFebruary 14, 2137; 114 years' time0
mghzawi
New Registration
w212 year 2012 E200 CGI
my analog clock in my instrument cluster ( Mercedes w212 year 2012 ) stopped working after adding the AMG menu , the clock in the command still working by the analog one stopped . the car was made for middle east and no GPS or maps activated in it . just the analog clock sync with the one in the command unit . the command is NTG 4.5 . no ability to edit the clock from the instrument cluster itself . any help how to fix that ? thanks .
Not_Anumber
I gave up with trying to understand why my analogue clock doesnt align and now just regard it as a waste of space in the instrument cluster. So long as the digital clock reads the right time thats ok.
