MB_FTB
- Mar 5, 2013
- Location
- Wimbledon
- 2012 E250 CDI Estate
Having a couple of issues with check engine light and air con, not sure if they are related to each other but they happened at the same time. Dealer's tech dept. is closed today so need some help here.
Check engine light started to display yesterday, I tried switching the engine off and back on wouldn't help. The car has only done less than 1000 miles so I wouldn't think it requires servicing?
When this happened, I also found air con not working, not that it couldn't produce cold air, but it couldn't be switched on full stop. Normally when it's off, you'd see a red light on top of the "OFF" button, but yesterday there was no red light and none of the buttons on air con was working nor responding.
I tried the air con this morning it appeared to working fine again, but I still suspect there is something wrong here, and the check engine light is still on.
Will call dealer tomorrow anyway, but any ideas why this is happening? Can I still drive the car without damaging the engine?
