Problems with sl320 engine
ecaf
i have an SL320 which has problems with the engine, it goes in to safe mode at high revs, the diagnosis machines says that it is three injectors, would anyone know what would be the best way forward
I cannot see why 3 injector should fail at once, is it the V6
E
ecaf
yes, it is the V6, any suggestions as to what it could be, im really struggling, just replaced the gearbox which cost a fortune, its burning a hole in an already burned pocket!!!
many thanx
If it was missing on 3 then the car would be hard to drive,if at all. Does the engine really shake when the fault happens
E
ecaf
initially it is fine, and if you was to drive with a very calm foot it would be ok, however as soon as you try and accelerate a bit more, the engine will go quite shaky and you would be unable to accelerate. once the engine is switched off and restarted it will be ok again.
E
ecaf
sorry to sound so stupid, but what is the MAF?
Some folk call it a Mass air intake sensor,,it is the biggest reason going for you fault, just pull the plug out and try
E
ecaf
many thanx for your assistance, i shall try that today, once i have finished at work, hopefully give you some feedback tomorrow,
much appreciaited.
